Ga door naar hoofdinhoud
Samsung Epic 4G Micro USB Port Replacement
Wat je nodig hebt
  1. Samsung Epic 4G Micro USB Port Replacement, Phone Case: stap 1, afbeelding 1 van 1
    • Slide your fingernail along the edge of the device and pull at the plastic backing.
    • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
  2. Samsung Epic 4G Micro USB Port Replacement: stap 2, afbeelding 1 van 1
    • Pull at the plastic backing gently to remove it after hearing the snap sound.
  3. Samsung Epic 4G Micro USB Port Replacement, Battery: stap 3, afbeelding 1 van 1
    • Remove the battery from the device by pulling the battery edge upwards.
  4. Samsung Epic 4G Micro USB Port Replacement, Removing the Memory Card:: stap 4, afbeelding 1 van 1
    • Locate the memory card on the upper right-hand corner of the device.
    • Remove the memory card from the device by gently sliding it out of its holder with your fingers.
  5. Samsung Epic 4G Micro USB Port Replacement, Removing the Back Housing: stap 5, afbeelding 1 van 2 Samsung Epic 4G Micro USB Port Replacement, Removing the Back Housing: stap 5, afbeelding 2 van 2
    • Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
    • Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
    • While separating the two components, most of the buttons (including the power button) will fall out.
  6. Samsung Epic 4G Micro USB Port Replacement, Removing the Power Button: stap 6, afbeelding 1 van 2 Samsung Epic 4G Micro USB Port Replacement, Removing the Power Button: stap 6, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the power button using tweezers if it did not fall out in the previous step.
    • At this point, you can replace the power button with a new one from a manufacturer.
  7. Samsung Epic 4G Micro USB Port Replacement, Micro USB Port: stap 7, afbeelding 1 van 1
    • Remove the white cable along the right side of the device (next to the battery housing) using the nylon spudger.
    • Pull out both ends of the white cable. They will easily snap out of place without excessive tension.
    • Do not rip the white cables out of the device.
  8. Samsung Epic 4G Micro USB Port Replacement, Removing the Antenna Assembly: stap 8, afbeelding 1 van 2 Samsung Epic 4G Micro USB Port Replacement, Removing the Antenna Assembly: stap 8, afbeelding 2 van 2
    • Remove the screw holding the antenna assembly in place using a Tri-Point Y0 screwdriver.
    • Snap the antenna assembly out of the device gently using your fingers.
  9. Samsung Epic 4G Micro USB Port Replacement, Removing the Flex Cable: stap 9, afbeelding 1 van 2 Samsung Epic 4G Micro USB Port Replacement, Removing the Flex Cable: stap 9, afbeelding 2 van 2
    • Pry the flex cable from the top of the phone by carefully using a nylon spudger.
    • Repeat this step for the larger flex cable located on the left side of the device below the smaller one.
  10. Samsung Epic 4G Micro USB Port Replacement: stap 10, afbeelding 1 van 1
    • Lift and remove the motherboard from the device.
    • The USB port is located at the top of the motherboard. At this point, replace the port with a new one from a manufacturer.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Andrew Cunningham
273 Reputatie
6 handleidingen geschreven
Cal Poly, Team 24-25, Regan Fall 2012 Lid van Cal Poly, Team 24-25, Regan Fall 2012
CPSU-REGAN-F12S24G25
4 Leden
7 handleidingen geschreven
Één opmerking
My phone doesn’t have a memory card. At least, not that I can see. What should I do?
Joshua Campbell - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 2,376
