Inleiding
After operating the phone for an extended period of time, the battery will deplete. With regular use, a battery will lose its charge within 24 hours of the phone's separation from the charger. If your battery starts to deplete quicker than it used to, you should replace the component. This guide tells you how to replace your current battery with a new one. Replacement batteries are easily found online via a Internet search.
Wat je nodig hebt
Slide your fingernail along the edge of the device and pull at the plastic backing.
4 andere personen hebben deze handleiding voltooid.
