1. with the front of the device facing you, turn the device 180 degrees so the back panel of the device is facing you
    • with the front of the device facing you, turn the device 180 degrees so the back panel of the device is facing you
  2. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  3. locate the three (3) screws on the back panel of the device that are implanted in the device
    • locate the three (3) screws on the back panel of the device that are implanted in the device
    • to remove the screws, use the tool(s) listed above (right underneath the introduction) and twist the screws counter-clockwise to remove them from the device
  4. to remove the cover of the device, pull the cover towards the back of the device until it is completely removed so you can see the insides of the device
    • to remove the cover of the device, pull the cover towards the back of the device until it is completely removed so you can see the insides of the device
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Devon Clements
228 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 1-6, Duarte Fall 2014 Lid van UMass Dartmouth, Team 1-6, Duarte Fall 2014
UMASSD-DUARTE-F14S1G6
3 Leden
7 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 2
Altijd: 163
