Ga door naar hoofdinhoud
Samsung DV300F Lens Replacement
Wat je nodig hebt
  1. Samsung DV300F Lens Replacement, Front and Rear Casing: stap 1, afbeelding 1 van 3 Samsung DV300F Lens Replacement, Front and Rear Casing: stap 1, afbeelding 2 van 3 Samsung DV300F Lens Replacement, Front and Rear Casing: stap 1, afbeelding 3 van 3
    • Remove the two black 4.2 mm screws on the right side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the left side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the bottom of the camera using a Phillips #0 screwdriver.
    Only one screw on bottom of camera
    John Petralito - Antwoord
  2. Samsung DV300F Lens Replacement: stap 2, afbeelding 1 van 2 Samsung DV300F Lens Replacement: stap 2, afbeelding 2 van 2
    • Remove the back case of the camera carefully.
    The covers are attached with very small tabs around the cover perimeter. A very small blade screwdriver is helpful in prizing the covers apart and off.
    JM Johnson - Antwoord
  3. Samsung DV300F Lens Replacement: stap 3, afbeelding 1 van 3 Samsung DV300F Lens Replacement: stap 3, afbeelding 2 van 3 Samsung DV300F Lens Replacement: stap 3, afbeelding 3 van 3
    • Remove the front case of the camera.
    • Remove the front LCD screen from the front case next to the lens.
  4. Samsung DV300F Lens Replacement, Back Button Control: stap 4, afbeelding 1 van 2 Samsung DV300F Lens Replacement, Back Button Control: stap 4, afbeelding 2 van 2
    • Remove the blue button control from its position next to the LCD screen.
    • Pull the ribbon cable to disconnect the blue button control from the camera.
  5. Samsung DV300F Lens Replacement, Back LCD Screen: stap 5, afbeelding 1 van 1
    • Remove the back LCD screen from its place carefully.
    samsung es90 lcd Where to call the address
    ianam73 73 - Antwoord
    I live in Bangladesh
    The white LCD is attached to the housing with sticky tape. Again a small blade screwdriver is helpful to CAREFULLY pry it out.
    Where can i find a replacement lcd screen?
    Jason Bills - Antwoord
  6. Samsung DV300F Lens Replacement: stap 6, afbeelding 1 van 2 Samsung DV300F Lens Replacement: stap 6, afbeelding 2 van 2
    • Flip the black tab where the back LCD screen connects to the circuit board.
    • Pull the tape connection to disconnect the back LCD screen from the circuit board.
  7. Samsung DV300F Lens Replacement, Lens: stap 7, afbeelding 1 van 2 Samsung DV300F Lens Replacement, Lens: stap 7, afbeelding 2 van 2
    • Unscrew the 3 silver #0 Phillips 4.45mm screws from the circuit board cover
    • Remove the circuit board cover
  8. Samsung DV300F Lens Replacement: stap 8, afbeelding 1 van 2 Samsung DV300F Lens Replacement: stap 8, afbeelding 2 van 2
    • Flip the first black tab connecting the lens to the circuit board
    • Flip the second black tab connecting the lens to the circuit board
    • Push the lens out from the front to remove it from the camera
Conclusie
5 andere personen hebben deze handleiding voltooid.
Timothy Gordon
820 Reputatie
5 handleidingen geschreven
Baylor, Team 5-10, Williams Spring 2015 Lid van Baylor, Team 5-10, Williams Spring 2015
BU-WILLIAMS-S15S5G10
3 Leden
10 handleidingen geschreven
Één opmerking
pourquoi ne pas aussi montrer comment demonter le lens de samsung dv300f
nouzalek - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 28
Altijd: 1,773
