Ga door naar hoofdinhoud
Samsung DV300F Front and Rear Casing Replacement
Wat je nodig hebt
  1. Samsung DV300F Front and Rear Casing Replacement, Front and Rear Casing: stap 1, afbeelding 1 van 3 Samsung DV300F Front and Rear Casing Replacement, Front and Rear Casing: stap 1, afbeelding 2 van 3 Samsung DV300F Front and Rear Casing Replacement, Front and Rear Casing: stap 1, afbeelding 3 van 3
    • Remove the two black 4.2 mm screws on the right side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the left side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the bottom of the camera using a Phillips #0 screwdriver.
  2. Samsung DV300F Front and Rear Casing Replacement: stap 2, afbeelding 1 van 2 Samsung DV300F Front and Rear Casing Replacement: stap 2, afbeelding 2 van 2
    • Remove the back case of the camera carefully.
  3. Samsung DV300F Front and Rear Casing Replacement: stap 3, afbeelding 1 van 3 Samsung DV300F Front and Rear Casing Replacement: stap 3, afbeelding 2 van 3 Samsung DV300F Front and Rear Casing Replacement: stap 3, afbeelding 3 van 3
    • Remove the front case of the camera.
    • Remove the front LCD screen from the front case next to the lens.
Conclusie
Timothy Gordon
820 Reputatie
5 handleidingen geschreven
Baylor, Team 5-10, Williams Spring 2015 Lid van Baylor, Team 5-10, Williams Spring 2015
BU-WILLIAMS-S15S5G10
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 22
Altijd: 535
