Ga door naar hoofdinhoud
Samsung DV180F Repair Display Screen Replacement
Wat je nodig hebt
  1. Samsung DV180F Repair Display Screen Replacement, Display Screen: stap 1, afbeelding 1 van 3 Samsung DV180F Repair Display Screen Replacement, Display Screen: stap 1, afbeelding 2 van 3 Samsung DV180F Repair Display Screen Replacement, Display Screen: stap 1, afbeelding 3 van 3
    • Use a pry tool to push the highlighted blue latch away from the battery in the direction of the arrow. Remove the battery.
    • Use the Phillips 000 Bit to remove all screws from the perimeter of the device. Set aside.
    • Use a small Plastic Opening Tool at the seam by the Micro USB plug. Separate the plastic case from the device.
  2. Samsung DV180F Repair Display Screen Replacement: stap 2, afbeelding 1 van 2 Samsung DV180F Repair Display Screen Replacement: stap 2, afbeelding 2 van 2
    • Remove the outer casing holding the back part of the camera together. Leave on the front casing.
    • Use a Phillips screwdriver to remove the two small screws holding the outer casing to the mother board.
    • Use the prying tool to unhook the casing from the plate covering the motherboard
  3. Samsung DV180F Repair Display Screen Replacement: stap 3, afbeelding 1 van 3 Samsung DV180F Repair Display Screen Replacement: stap 3, afbeelding 2 van 3 Samsung DV180F Repair Display Screen Replacement: stap 3, afbeelding 3 van 3
    • Release the ribbon from the button casing connected to the motherboard.
    • Hold the metal casing out of the way and snap the ribbon connector back. Remove the display screen ribbon attached.
    • Replace the screen then repeat all of these steps in reverse order to reassemble.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Evan McGettrick
232 Reputatie
1 Handleiding geschreven
USF Tampa, Team 14-4, Eyestone Fall 2016 Lid van USF Tampa, Team 14-4, Eyestone Fall 2016
USFT-EYESTONE-F16S14G4
4 Leden
8 handleidingen geschreven
2Gids Commentaar
I got it open in the hope of finding a screen ID. I can not find a replacement screen for the DV180F. do you know if the DV150 screen will work?
lrrpbill68 - Antwoord Deel
im looking for a screen as well were you able to find a replacement?
Sidath Paranavithane - Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 40
Altijd: 962
