Ga door naar hoofdinhoud
Samsung DV180F Repair Battery Replacement
Wat je nodig hebt
  1. Samsung DV180F Repair Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Samsung DV180F Repair Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Locate the battery door and slide it to the right to unlatch it. Swing the battery door up to expose the battery chamber.
    • Ensure that the camera is turned off before attempting to replace the battery.
  2. Samsung DV180F Repair Battery Replacement: stap 2, afbeelding 1 van 1
    • Locate the blue latch that holds the battery in the battery chamber. Using your fingernail or a plastic opening tool, push it away from the battery, in the direction of the arrow on the latch.
  3. Samsung DV180F Repair Battery Replacement: stap 3, afbeelding 1 van 2 Samsung DV180F Repair Battery Replacement: stap 3, afbeelding 2 van 2
    • Once the latch is disengaged, the battery should pop up. Grab the battery and slide it up and out of the camera.
  4. Samsung DV180F Repair Battery Replacement: stap 4, afbeelding 1 van 1
    • Move the blue latch out of the way and slide the replacement battery into the battery chamber. Lightly push until the battery clicks in place. Close the battery door.
    • Make sure that the replacement battery is oriented correctly.
Conclusie
maria
244 Reputatie
2 handleidingen geschreven
USF Tampa, Team 14-4, Eyestone Fall 2016 Lid van USF Tampa, Team 14-4, Eyestone Fall 2016
USFT-EYESTONE-F16S14G4
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 365
