Ga door naar hoofdinhoud
Samsung Chromebook XE550C22 Battery Replacement
Wat je nodig hebt
  1. Samsung Chromebook XE550C22 Battery Replacement, Back Panel: stap 1, afbeelding 1 van 3 Samsung Chromebook XE550C22 Battery Replacement, Back Panel: stap 1, afbeelding 2 van 3 Samsung Chromebook XE550C22 Battery Replacement, Back Panel: stap 1, afbeelding 3 van 3
    • Turn the power off before beginning this step.
    • Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
  2. Samsung Chromebook XE550C22 Battery Replacement: stap 2, afbeelding 1 van 2 Samsung Chromebook XE550C22 Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the eight 7mm screws using the J0 Screwdriver.
  3. Samsung Chromebook XE550C22 Battery Replacement: stap 3, afbeelding 1 van 3 Samsung Chromebook XE550C22 Battery Replacement: stap 3, afbeelding 2 van 3 Samsung Chromebook XE550C22 Battery Replacement: stap 3, afbeelding 3 van 3
    • Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
    • Continue prying around the sides to release more brackets.
  4. Samsung Chromebook XE550C22 Battery Replacement: stap 4, afbeelding 1 van 2 Samsung Chromebook XE550C22 Battery Replacement: stap 4, afbeelding 2 van 2
    • After deconnecting all the brackets, pull the back panel away from the laptop.
    • Note: The back panel has some flex to it, don't be afraid to use some force.
  5. Samsung Chromebook XE550C22 Battery Replacement, Battery: stap 5, afbeelding 1 van 2 Samsung Chromebook XE550C22 Battery Replacement, Battery: stap 5, afbeelding 2 van 2
    • Remove the four 3mm screws holding the battery with the J0 screwdriver.
  6. Samsung Chromebook XE550C22 Battery Replacement: stap 6, afbeelding 1 van 2 Samsung Chromebook XE550C22 Battery Replacement: stap 6, afbeelding 2 van 2
    • Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
    • Do not lift the battery straight up. This will damage the battery's connectors.
Conclusie
Brenna Wolfe
541 Reputatie
3 handleidingen geschreven
CSU Fullerton, Team S2-G7, Bruce Fall 2017 Lid van CSU Fullerton, Team S2-G7, Bruce Fall 2017
CSUF-BRUCE-F17S2G7
3 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 504
