Inleiding
This guide will help you replace your battery in your Chromebook by showing you step-by-step on how to remove it.
Wat je nodig hebt
Lay the Chromebook down so that the bottom cover is facing upward.
Using a Phillips #00 screwdriver, remove all seven 5.5 mm screws from the back cover.
Bijna klaar!
Conclusie
