Ga door naar hoofdinhoud
Samsung Chromebook Series 3 Speaker Replacement
Wat je nodig hebt
  1. Samsung Chromebook Series 3 Speaker Replacement, Bottom Cover: stap 1, afbeelding 1 van 3 Samsung Chromebook Series 3 Speaker Replacement, Bottom Cover: stap 1, afbeelding 2 van 3 Samsung Chromebook Series 3 Speaker Replacement, Bottom Cover: stap 1, afbeelding 3 van 3
    • Lay the Chromebook down so that the bottom cover is facing up.
    • Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
  2. Samsung Chromebook Series 3 Speaker Replacement: stap 2, afbeelding 1 van 3 Samsung Chromebook Series 3 Speaker Replacement: stap 2, afbeelding 2 van 3 Samsung Chromebook Series 3 Speaker Replacement: stap 2, afbeelding 3 van 3
    • Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver.
  3. Samsung Chromebook Series 3 Speaker Replacement: stap 3, afbeelding 1 van 3 Samsung Chromebook Series 3 Speaker Replacement: stap 3, afbeelding 2 van 3 Samsung Chromebook Series 3 Speaker Replacement: stap 3, afbeelding 3 van 3
    • Pry up the plastic strip on the back of the Chromebook using a plastic opening tool.
    • It is not necessary to remove it completely. It just needs to be separated from the bottom cover.
  4. Samsung Chromebook Series 3 Speaker Replacement: stap 4, afbeelding 1 van 3 Samsung Chromebook Series 3 Speaker Replacement: stap 4, afbeelding 2 van 3 Samsung Chromebook Series 3 Speaker Replacement: stap 4, afbeelding 3 van 3
    • Pry off the bottom cover using a plastic opening tool.
  5. Samsung Chromebook Series 3 Speaker Replacement, Battery: stap 5, afbeelding 1 van 3 Samsung Chromebook Series 3 Speaker Replacement, Battery: stap 5, afbeelding 2 van 3 Samsung Chromebook Series 3 Speaker Replacement, Battery: stap 5, afbeelding 3 van 3
    • Remove six 3.5 mm screws holding the battery using a Phillips #00 screwdriver.
    • Pull out the battery partway in order to easily get to the battery connector.
  6. Samsung Chromebook Series 3 Speaker Replacement: stap 6, afbeelding 1 van 3 Samsung Chromebook Series 3 Speaker Replacement: stap 6, afbeelding 2 van 3 Samsung Chromebook Series 3 Speaker Replacement: stap 6, afbeelding 3 van 3
    • Disconnect the battery connector by pulling straight up at its base.
    • When reassembling, simply position the connector above it's original place, and push down.
  7. Samsung Chromebook Series 3 Speaker Replacement: stap 7, afbeelding 1 van 2 Samsung Chromebook Series 3 Speaker Replacement: stap 7, afbeelding 2 van 2
    • You can now remove the battery.
  8. Samsung Chromebook Series 3 Speaker Replacement, Speaker: stap 8, afbeelding 1 van 3 Samsung Chromebook Series 3 Speaker Replacement, Speaker: stap 8, afbeelding 2 van 3 Samsung Chromebook Series 3 Speaker Replacement, Speaker: stap 8, afbeelding 3 van 3
    • Disconnect the cable connecting the speakers to the motherboard by pulling on it away from the motherboard.
  9. Samsung Chromebook Series 3 Speaker Replacement: stap 9, afbeelding 1 van 3 Samsung Chromebook Series 3 Speaker Replacement: stap 9, afbeelding 2 van 3 Samsung Chromebook Series 3 Speaker Replacement: stap 9, afbeelding 3 van 3
    • Lift up the piece of tape covering the trackpad ribbon cable.
    • Lift up the lock on the trackpad ribbon cable using a plastic opening tool.
    • Disconnect the trackpad ribbon cable by pulling it out.
  10. Samsung Chromebook Series 3 Speaker Replacement: stap 10, afbeelding 1 van 2 Samsung Chromebook Series 3 Speaker Replacement: stap 10, afbeelding 2 van 2
    • Lift up the trackpad ribbon cable so that it is not covering the speaker wire.
    • Lift up the two pieces of metallic tape so that they no longer cover the speaker wire.
    • When reassembling the device, make sure to lay down the metallic tape in the same place it was prior to disassembly. The tape serves as a connector for certain electrical circuits that should not be disconnected.
  11. Samsung Chromebook Series 3 Speaker Replacement: stap 11, afbeelding 1 van 3 Samsung Chromebook Series 3 Speaker Replacement: stap 11, afbeelding 2 van 3 Samsung Chromebook Series 3 Speaker Replacement: stap 11, afbeelding 3 van 3
    • Unscrew the four 3.7 mm screws holding down the speakers using a Phillips #00 screwdriver.
  12. Samsung Chromebook Series 3 Speaker Replacement: stap 12, afbeelding 1 van 2 Samsung Chromebook Series 3 Speaker Replacement: stap 12, afbeelding 2 van 2
    • Pull the speakers up to remove them.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Andrey Radchishin
1.860 Reputatie
4 handleidingen geschreven
UWT Liner: Group 1 Lid van UWT Liner: Group 1
Community
5 Leden
8 handleidingen geschreven
Één opmerking
Many thanks.
Excellent guide .
Triumph Trident - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 1,611
