Ga door naar hoofdinhoud
Samsung Chromebook Plus Battery Replacement
Wat je nodig hebt
  1. Samsung Chromebook Plus Battery Replacement, Removing back panel screws: stap 1, afbeelding 1 van 1
    • Remove the 8 PHILIPS#0 screws
  2. Samsung Chromebook Plus Battery Replacement, Removing back panel: stap 2, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    Koop
    • Stick a plastic card (or fingernail) into the gap between panel and the body. Then lift the panel up (long side with speakers closest).
  3. Samsung Chromebook Plus Battery Replacement, Removing battery screws: stap 3, afbeelding 1 van 1
    • Use your PHILIPS#0 and remove the 4 screws
  4. Samsung Chromebook Plus Battery Replacement, Removing the battery: stap 4, afbeelding 1 van 1
    • Lift battery from bottom side first (marked with red line)
  5. Samsung Chromebook Plus Battery Replacement, Finally detaching the battery: stap 5, afbeelding 1 van 1
    • Detach battery cable grabbing the side and pulling the cable upward.
  6. Samsung Chromebook Plus Battery Replacement, Inserting the new battery: stap 6, afbeelding 1 van 1
    • Insert the battery and push the plug into the socket downward.
  7. Samsung Chromebook Plus Battery Replacement, Re-inserting the screws: stap 7, afbeelding 1 van 1
    • Re-insert the screws in the holes circled red (on this image), which is where you removed them previously.
  8. Samsung Chromebook Plus Battery Replacement, The back panel gets re-inserted: stap 8, afbeelding 1 van 1
    • Insert the hinge-side middle screw (must be done first otherwise casing may bulge) and insert rest of panel. On the hinge side, press down on the sides (if there is bulging) until you hear it snap. Insert the two other hinge-side screws (marked with orange on image). After that, insert the other 5 screws (yellow).
Conclusie
To reassemble your device, skip steps 1-5.
7 andere personen hebben deze handleiding voltooid.
Evan Elm
1.023 Reputatie
3 handleidingen geschreven
Kid fixers Lid van Kid fixers
Community
169 Leden
226 handleidingen geschreven
6 opmerkingen
Great repair guide. Nice to see how easy it is to replace battery.
N ick - Antwoord
Does anyone know where you can get a replacement battery?
Stanley Fujimoto - Antwoord
Sadly no, I have no idea, chromebookparts.com doesn't have a part either, haven't found one anywhere yet
Evan Elm -
I managed to find a replacement part, see the parts section at the top of the guide :)
Evan Elm -
thanks for finding the battery part! Awesome job!
JT Cen - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 54
Altijd: 6,953
