Ga door naar hoofdinhoud
Samsung Chromebook 3 XE500C13-K02US Speakers Replacement
Wat je nodig hebt
  1. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement, Bottom Case: stap 1, afbeelding 1 van 2 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement, Bottom Case: stap 1, afbeelding 2 van 2
    • Place the laptop back cover facing up to expose the screws.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: stap 2, afbeelding 1 van 2 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: stap 2, afbeelding 2 van 2
    • Use an iFixit opening tool to wedge in between the case and body of the laptop.
    • Once the tool is wedged in between the case and laptop, slide it around the entire laptop's edge to disengage the retaining clips.
    • You should hear a popping sound as you slide the iFixit opening tool around the laptop.
  3. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: stap 3, afbeelding 1 van 2 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: stap 3, afbeelding 2 van 2
    • Remove the cover exposing the inside of the laptop.
  4. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement, Battery: stap 4, afbeelding 1 van 2 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement, Battery: stap 4, afbeelding 2 van 2
    • Remove the four 4.6mm screws with the Phillips #00 screwdriver.
  5. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: stap 5, afbeelding 1 van 3 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: stap 5, afbeelding 2 van 3 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: stap 5, afbeelding 3 van 3
    • Use the spudger to pry underneath the cable and gently lift the connector up.
  6. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: stap 6, afbeelding 1 van 1
    • Lift the battery up and out of the case.
  7. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement, Speakers: stap 7, afbeelding 1 van 2 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement, Speakers: stap 7, afbeelding 2 van 2
    • Remove two 4.9mm silver screws with a Phillips #00 screwdriver.
    • Each speaker only has 1 screw.
  8. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: stap 8, afbeelding 1 van 2 Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: stap 8, afbeelding 2 van 2
    • Use the spudger to pry the speaker connector sideways out out of the motherboard.
    • Repeat this step for the left speaker.
  9. Samsung Chromebook 3 XE500C13-K02US Speakers Replacement: stap 9, afbeelding 1 van 1
    • Remove the speakers by lifting them upwards and out of the laptop.
Conclusie
Mick McCarty
980 Reputatie
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 287
