Inleiding
This guide is a step-by-step guide on how to replace the Samsung Chromebook 3 XE500C13-K02US I/O board with integrated Wi-Fi card. You will need to remove the battery, disconnect the I/O board from the motherboard, remove the 2 pins speaker connecter, and the black and white wire running into the hinge cover
Wat je nodig hebt
Place the laptop back cover facing up to expose all nine 4.6 mm screws.
Remove all nine 4.6 mm screws using a Phillips #00 screwdriver.
