Inleiding
This guide illustrates how to remove the Samsung Chromebook 3 XE500C13-K02US battery. You will need to open the device’s back panel as the battery is located inside the case.
Wat je nodig hebt
Place the laptop back cover facing up to expose the screws.
Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
