Ga door naar hoofdinhoud
Samsung Chromebook 3 Motherboard Replacement
Wat je nodig hebt
  1. Samsung Chromebook 3 Motherboard Replacement, Bottom Case: stap 1, afbeelding 1 van 2 Samsung Chromebook 3 Motherboard Replacement, Bottom Case: stap 1, afbeelding 2 van 2
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 Motherboard Replacement: stap 2, afbeelding 1 van 3 Samsung Chromebook 3 Motherboard Replacement: stap 2, afbeelding 2 van 3 Samsung Chromebook 3 Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Lift the case up and off the device
  4. Samsung Chromebook 3 Motherboard Replacement, Battery: stap 4, afbeelding 1 van 2 Samsung Chromebook 3 Motherboard Replacement, Battery: stap 4, afbeelding 2 van 2
    • Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
  5. Samsung Chromebook 3 Motherboard Replacement: stap 5, afbeelding 1 van 2 Samsung Chromebook 3 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Use a spudger to gently pry the power cable cord upwards from the motherboard.
  6. Samsung Chromebook 3 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Lift the battery up and out from the case.
  7. Samsung Chromebook 3 Motherboard Replacement, Motherboard: stap 7, afbeelding 1 van 3 Samsung Chromebook 3 Motherboard Replacement, Motherboard: stap 7, afbeelding 2 van 3 Samsung Chromebook 3 Motherboard Replacement, Motherboard: stap 7, afbeelding 3 van 3
    • Before you can get to the motherboard, remove the three 4.6mm screws from the port cover using a Phillips #00 screwdriver.
  8. Samsung Chromebook 3 Motherboard Replacement: stap 8, afbeelding 1 van 3 Samsung Chromebook 3 Motherboard Replacement: stap 8, afbeelding 2 van 3 Samsung Chromebook 3 Motherboard Replacement: stap 8, afbeelding 3 van 3
    • Then, use a spudger to begin flipping up the grey covers on the ZIF connectors.
  9. Samsung Chromebook 3 Motherboard Replacement: stap 9, afbeelding 1 van 3 Samsung Chromebook 3 Motherboard Replacement: stap 9, afbeelding 2 van 3 Samsung Chromebook 3 Motherboard Replacement: stap 9, afbeelding 3 van 3
    • Two more ZIF connectors to go!
  10. Samsung Chromebook 3 Motherboard Replacement: stap 10, afbeelding 1 van 2 Samsung Chromebook 3 Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Use a spudger to disconnect the cables going to the speaker by prying outward to the right.
  11. Samsung Chromebook 3 Motherboard Replacement: stap 11, afbeelding 1 van 3 Samsung Chromebook 3 Motherboard Replacement: stap 11, afbeelding 2 van 3 Samsung Chromebook 3 Motherboard Replacement: stap 11, afbeelding 3 van 3
    • Use a spudger to lift the hinge locking the gold colored display cable in place.
    • Then gently coax the display cable from its connector using your fingers or a spudger.
  12. Samsung Chromebook 3 Motherboard Replacement: stap 12, afbeelding 1 van 2 Samsung Chromebook 3 Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Use your Phillips #00 screwdriver to remove four 4.6mm screws from the motherboard.
  13. Samsung Chromebook 3 Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Ensure all cables are clear and remove the motherboard.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Austin Blakely
19.863 Reputatie
53 handleidingen geschreven
iFixit Lid van iFixit
Staff
141 Leden
17.903 handleidingen geschreven
Één opmerking
Thanks for the great guide! I used it to remove the write protection screw on the back of the motherboard.
My Chromebook is model number XE501C13. The only difference I noticed is that there is one less screw on the outer plastic cover. Everything else is exactly the same!
Edward Fernandez - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 41
Altijd: 3,001
