Ga door naar hoofdinhoud
Samsung Captivate Rear Case Replacement
Wat je nodig hebt
  1. Samsung Captivate Rear Case Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
  2. Samsung Captivate Rear Case Replacement: stap 2, afbeelding 1 van 1
    • Place your finger on the bottom of the battery and lift to remove.
  3. Samsung Captivate Rear Case Replacement: stap 3, afbeelding 1 van 1
    • Replace the old battery with the new one.
  4. Samsung Captivate Rear Case Replacement, Rear Case: stap 4, afbeelding 1 van 1
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
  5. Samsung Captivate Rear Case Replacement: stap 5, afbeelding 1 van 1
    • Remove the six 4.5mm #000 Phillips screws.
  6. Samsung Captivate Rear Case Replacement: stap 6, afbeelding 1 van 3 Samsung Captivate Rear Case Replacement: stap 6, afbeelding 2 van 3 Samsung Captivate Rear Case Replacement: stap 6, afbeelding 3 van 3
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  7. Samsung Captivate Rear Case Replacement: stap 7, afbeelding 1 van 1
    • Separate the rear case from the phone.
Conclusie
12 andere personen hebben deze handleiding voltooid.
Christopher
643 Reputatie
4 handleidingen geschreven
Cal Poly, Team 20-25, Maness Fall 2011 Lid van Cal Poly, Team 20-25, Maness Fall 2011
CPSU-MANESS-F11S20G25
3 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 3,535
