Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Samsung Captivate Motherboard Replacement
Wat je nodig hebt
  1. Samsung Captivate Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
  2. Samsung Captivate Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Place your finger on the bottom of the battery and lift to remove.
  3. Samsung Captivate Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Replace the old battery with the new one.
  4. Samsung Captivate Motherboard Replacement, Rear Case: stap 4, afbeelding 1 van 1
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
  5. Samsung Captivate Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the six 4.5mm #000 Phillips screws.
  6. Samsung Captivate Motherboard Replacement: stap 6, afbeelding 1 van 3 Samsung Captivate Motherboard Replacement: stap 6, afbeelding 2 van 3 Samsung Captivate Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  7. Samsung Captivate Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Separate the rear case from the phone.
  8. Samsung Captivate Motherboard Replacement, Antenna Cable: stap 8, afbeelding 1 van 2 Samsung Captivate Motherboard Replacement, Antenna Cable: stap 8, afbeelding 2 van 2
    • Use a spudger tool to pry up the antenna cable from the connector on the motherboard.
    • Pry up the other end of the cable from the connector on the antenna array.
  9. Samsung Captivate Motherboard Replacement, Speaker: stap 9, afbeelding 1 van 1
    • Use the Phillips 00 screwdriver to remove the single screw holding the speaker assembly to the LCD.
  10. Samsung Captivate Motherboard Replacement: stap 10, afbeelding 1 van 2 Samsung Captivate Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Use the plastic opening tool to lift the bottom tab of the plastic ribbon cable connector. Be careful not to use excessive force, you are only releasing the tab that holds the cable in.
    • Pull out the ribbon cable.
    • Use a spudger or plastic opening tool to lift up the speaker, and use your hands to remove it.
  11. Samsung Captivate Motherboard Replacement, Camera Assembly: stap 11, afbeelding 1 van 2 Samsung Captivate Motherboard Replacement, Camera Assembly: stap 11, afbeelding 2 van 2
    • Lift up the black NEC chip with attached ribbon cable using either a spudger or plastic opening tool.
    • Gently lift the camera assembly out of the plastic housing.
  12. Samsung Captivate Motherboard Replacement, Motherboard: stap 12, afbeelding 1 van 3 Samsung Captivate Motherboard Replacement, Motherboard: stap 12, afbeelding 2 van 3 Samsung Captivate Motherboard Replacement, Motherboard: stap 12, afbeelding 3 van 3
    • Use a spudger to disconnect the three highlighted connectors.
    • Pry straight up and be careful to pry against the connector, not the socket on the motherboard itself.
  13. Samsung Captivate Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Use your fingers to lift up the logic board from the assembly.
Conclusie
14 andere personen hebben deze handleiding voltooid.
Christopher
643 Reputatie
4 handleidingen geschreven
Cal Poly, Team 20-25, Maness Fall 2011 Lid van Cal Poly, Team 20-25, Maness Fall 2011
CPSU-MANESS-F11S20G25
3 Leden
9 handleidingen geschreven
Één opmerking
hi, I have the captivate and I cannot get it to charge, i have had the charging port connection repaired in the past, but now I cannot get it to charge again
Mary B Chalfant - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 13,586
