Ga door naar hoofdinhoud
Samsung Captivate Earpiece Replacement
Wat je nodig hebt
  1. Samsung Captivate Earpiece Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
  2. Samsung Captivate Earpiece Replacement: stap 2, afbeelding 1 van 1
    • Place your finger on the bottom of the battery and lift to remove.
  3. Samsung Captivate Earpiece Replacement: stap 3, afbeelding 1 van 1
    • Replace the old battery with the new one.
  4. Samsung Captivate Earpiece Replacement, Rear Case: stap 4, afbeelding 1 van 1
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
  5. Samsung Captivate Earpiece Replacement: stap 5, afbeelding 1 van 1
    • Remove the six 4.5mm #000 Phillips screws.
  6. Samsung Captivate Earpiece Replacement: stap 6, afbeelding 1 van 3 Samsung Captivate Earpiece Replacement: stap 6, afbeelding 2 van 3 Samsung Captivate Earpiece Replacement: stap 6, afbeelding 3 van 3
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  7. Samsung Captivate Earpiece Replacement: stap 7, afbeelding 1 van 1
    • Separate the rear case from the phone.
  8. Samsung Captivate Earpiece Replacement, Antenna Cable: stap 8, afbeelding 1 van 2 Samsung Captivate Earpiece Replacement, Antenna Cable: stap 8, afbeelding 2 van 2
    • Use a spudger tool to pry up the antenna cable from the connector on the motherboard.
    • Pry up the other end of the cable from the connector on the antenna array.
  9. Samsung Captivate Earpiece Replacement, Camera Assembly: stap 9, afbeelding 1 van 1
    • Use the spudger tool to pry up the chip labeled "NEC." This releases the chip.
  10. Samsung Captivate Earpiece Replacement: stap 10, afbeelding 1 van 1
    • Gently lift the camera assembly out of the plastic housing.
  11. Samsung Captivate Earpiece Replacement, Motherboard: stap 11, afbeelding 1 van 3 Samsung Captivate Earpiece Replacement, Motherboard: stap 11, afbeelding 2 van 3 Samsung Captivate Earpiece Replacement, Motherboard: stap 11, afbeelding 3 van 3
    • Use a spudger to disconnect the three highlighted connectors.
    • Pry straight up and be careful to pry against the connector, not the socket on the motherboard itself.
  12. Samsung Captivate Earpiece Replacement: stap 12, afbeelding 1 van 1
    • Use your fingers to lift up the logic board from the assembly.
  13. Samsung Captivate Earpiece Replacement, 3.5mm Headphone Jack: stap 13, afbeelding 1 van 2 Samsung Captivate Earpiece Replacement, 3.5mm Headphone Jack: stap 13, afbeelding 2 van 2
    • Gently pull up on the audio jack, taking the attached ribbon cable with it.
    • There is a small amount of glue holding the ribbon cable that attaches the audio jack to the earpiece.
  14. Samsung Captivate Earpiece Replacement, Earpiece: stap 14, afbeelding 1 van 1
    • The earpiece is attached to the 3.5mm audio jack. You will need to replace the entire assembly.
Conclusie
Drew Bentz
565 Reputatie
5 handleidingen geschreven
Cal Poly, Team 20-25, Maness Fall 2011 Lid van Cal Poly, Team 20-25, Maness Fall 2011
CPSU-MANESS-F11S20G25
3 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 2,312
