Ga door naar hoofdinhoud
Samsung Captivate 3.5mm Headphone Jack Replacement
Wat je nodig hebt
  1. Samsung Captivate 3.5mm Headphone Jack Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
    • Lift up the back cover.
  2. Samsung Captivate 3.5mm Headphone Jack Replacement: stap 2, afbeelding 1 van 1
    • Place your finger on the bottom of the battery and lift to remove.
  3. Samsung Captivate 3.5mm Headphone Jack Replacement: stap 3, afbeelding 1 van 1
    • Replace the old battery with the new one.
  4. Samsung Captivate 3.5mm Headphone Jack Replacement, Rear Case: stap 4, afbeelding 1 van 1
    • Insert the spudger underneath the bottom section of the phone.
    • Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
  5. Samsung Captivate 3.5mm Headphone Jack Replacement: stap 5, afbeelding 1 van 1
    • Remove the six 4.5mm #000 Phillips screws.
  6. Samsung Captivate 3.5mm Headphone Jack Replacement: stap 6, afbeelding 1 van 3 Samsung Captivate 3.5mm Headphone Jack Replacement: stap 6, afbeelding 2 van 3 Samsung Captivate 3.5mm Headphone Jack Replacement: stap 6, afbeelding 3 van 3
    • Starting at a bottom corner, use the spudger to separate the rear case from the front display.
    • Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
    • Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
  7. Samsung Captivate 3.5mm Headphone Jack Replacement: stap 7, afbeelding 1 van 1
    • Separate the rear case from the phone.
  8. Samsung Captivate 3.5mm Headphone Jack Replacement, Antenna Cable: stap 8, afbeelding 1 van 2 Samsung Captivate 3.5mm Headphone Jack Replacement, Antenna Cable: stap 8, afbeelding 2 van 2
    • Use a spudger tool to pry up the antenna cable from the connector on the motherboard.
    • Pry up the other end of the cable from the connector on the antenna array.
  9. Samsung Captivate 3.5mm Headphone Jack Replacement, Motherboard: stap 9, afbeelding 1 van 3 Samsung Captivate 3.5mm Headphone Jack Replacement, Motherboard: stap 9, afbeelding 2 van 3 Samsung Captivate 3.5mm Headphone Jack Replacement, Motherboard: stap 9, afbeelding 3 van 3
    • Use a spudger to disconnect the three highlighted connectors.
    • Pry straight up and be careful to pry against the connector, not the socket on the motherboard itself.
  10. Samsung Captivate 3.5mm Headphone Jack Replacement: stap 10, afbeelding 1 van 1
    • Use your fingers to lift up the logic board from the assembly.
  11. Samsung Captivate 3.5mm Headphone Jack Replacement, 3.5mm Headphone Jack: stap 11, afbeelding 1 van 2 Samsung Captivate 3.5mm Headphone Jack Replacement, 3.5mm Headphone Jack: stap 11, afbeelding 2 van 2
    • Gently pull up on the audio jack, taking the attached ribbon cable with it.
    • There is a small amount of glue holding the ribbon cable that attaches the audio jack to the earpiece.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Christopher
643 Reputatie
4 handleidingen geschreven
Cal Poly, Team 20-25, Maness Fall 2011 Lid van Cal Poly, Team 20-25, Maness Fall 2011
CPSU-MANESS-F11S20G25
3 Leden
9 handleidingen geschreven
Één opmerking
Between steps 7 and 8, there are a number of steps missing, including the removal of the camera, and the removal of the speaker assembly.
These can be found on the "Mother Board" repair manual, back on the device page.
~Desmond
Mobile Rapid Response Unit - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 7,632
