Ga door naar hoofdinhoud
Samsung CLP-300 Imaging Unit Replacement
  1. Samsung CLP-300 Imaging Unit Replacement, Imaging Unit: stap 1, afbeelding 1 van 1
    • Turn the printer off and wait a few minutes for it to cool.
  2. Samsung CLP-300 Imaging Unit Replacement: stap 2, afbeelding 1 van 2 Samsung CLP-300 Imaging Unit Replacement: stap 2, afbeelding 2 van 2
    • Open the front cover
  3. Samsung CLP-300 Imaging Unit Replacement: stap 3, afbeelding 1 van 1
    • Remove waste toner container from the printer.
  4. Samsung CLP-300 Imaging Unit Replacement: stap 4, afbeelding 1 van 3 Samsung CLP-300 Imaging Unit Replacement: stap 4, afbeelding 2 van 3 Samsung CLP-300 Imaging Unit Replacement: stap 4, afbeelding 3 van 3
    • Pull the imaging unit out of the printer using bottom handle.
    • Use green handle on top of imaging unit to steady unit as you pull it out.
    • Holding the top and bottom handles on the new imaging unit, slide the unit in the printer until you hear a “click.”
    • Remove new imaging unit from its packaging making sure to remove protective paper and devices from unit
    • Do not expose new imaging unit to light for more than a few minutes. Covering unit with a piece of paper is sufficient protection while you complete repair.
    • If you hear a crackling sound once the printer turns on the imaging unit is not installed correctly. Take out and reinsert the unit.
Conclusie
Heather Howard
586 Reputatie
4 handleidingen geschreven
University of Maine, Team 1-1, Diaz Fall 2014 Lid van University of Maine, Team 1-1, Diaz Fall 2014
UMAINE-DIAZ-F14S1G1
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 35
Altijd: 13,160
