Ga door naar hoofdinhoud
Samsung Brightside Logic board Replacement
Wat je nodig hebt
  1. Samsung Brightside Logic board Replacement, Logic board: stap 1, afbeelding 1 van 3 Samsung Brightside Logic board Replacement, Logic board: stap 1, afbeelding 2 van 3 Samsung Brightside Logic board Replacement, Logic board: stap 1, afbeelding 3 van 3
    • Here is the Samsung SCH-U380 Brightside
    • Turn it over to gain access to the battery.
    • Remove the backcover by simply pulling it off the phone from the top down
  2. Samsung Brightside Logic board Replacement: stap 2, afbeelding 1 van 3 Samsung Brightside Logic board Replacement: stap 2, afbeelding 2 van 3 Samsung Brightside Logic board Replacement: stap 2, afbeelding 3 van 3
    • Remove the battery
    • Remove the six Phillips screws from the back frame
    • All six screws are identical M1.5X3
  3. Samsung Brightside Logic board Replacement: stap 3, afbeelding 1 van 3 Samsung Brightside Logic board Replacement: stap 3, afbeelding 2 van 3 Samsung Brightside Logic board Replacement: stap 3, afbeelding 3 van 3
    • Use a plastic opening tool or similar tool to separate the top from the bottom frame. Applying slight pressure in a downwards direction will disengage the plastic clips
    • Continue to slide the tool along the slot until you feel the plastic locks disengage
    • Once all locks have released, the bottom frame can simply be removed.
  4. Samsung Brightside Logic board Replacement: stap 4, afbeelding 1 van 3 Samsung Brightside Logic board Replacement: stap 4, afbeelding 2 van 3 Samsung Brightside Logic board Replacement: stap 4, afbeelding 3 van 3
    • Remove the two Phillips screws from the EMI shield.
    • Both screws are identical M1.5X2
    • Remove the EMI shield
  5. Samsung Brightside Logic board Replacement: stap 5, afbeelding 1 van 2 Samsung Brightside Logic board Replacement: stap 5, afbeelding 2 van 2
    • Detach the LCD connector.
    • Remove the logic board
Conclusie
Één andere persoon heeft deze handleiding voltooid.
oldturkey03
782.133 Reputatie
119 handleidingen geschreven
Global Fixers Lid van Global Fixers
Community
33 Leden
537 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 1,513
