Ga door naar hoofdinhoud
Samsung Blast Keyboard Replacement
Wat je nodig hebt
  1. Samsung Blast Keyboard Replacement, At a Glance: stap 1, afbeelding 1 van 2 Samsung Blast Keyboard Replacement, At a Glance: stap 1, afbeelding 2 van 2
    • Your phone should look like this before disassembly.
  2. Samsung Blast Keyboard Replacement, Battery Case Removal: stap 2, afbeelding 1 van 2 Samsung Blast Keyboard Replacement, Battery Case Removal: stap 2, afbeelding 2 van 2
    • Remove the battery cover by sliding the back panel up. This will expose the battery.
  3. Samsung Blast Keyboard Replacement, Remove Battery/Sim card: stap 3, afbeelding 1 van 1
    • Lift up the top portion of the battery and pull it out.
    • Next, slide the sim card out of its socket and set it aside.
  4. Samsung Blast Keyboard Replacement, Back Case Removal: stap 4, afbeelding 1 van 2 Samsung Blast Keyboard Replacement, Back Case Removal: stap 4, afbeelding 2 van 2
    • Use a Phillips #00 Screwdriver to unscrew the six small screws that secure the back of the case.
    • The top two screws are connected to the back cover. They will not come off once unscrewed.
    • Remove the case by prying around the edges.
    • Note the positions of button pads for reassembly.
  5. Samsung Blast Keyboard Replacement, Button Pads: stap 5, afbeelding 1 van 2 Samsung Blast Keyboard Replacement, Button Pads: stap 5, afbeelding 2 van 2
    • Remove the buttons for the camera and volume.
  6. Samsung Blast Keyboard Replacement, Motherboard Removal: stap 6, afbeelding 1 van 3 Samsung Blast Keyboard Replacement, Motherboard Removal: stap 6, afbeelding 2 van 3 Samsung Blast Keyboard Replacement, Motherboard Removal: stap 6, afbeelding 3 van 3
    • Use a prying tool to detach the motherboard from main body.
    • Carefully detach the motherboard from the two connectors.
    • You could also use a pry tool for the second step.
    • Be careful with the motherboard as not to scrape or damage its components.
  7. Samsung Blast Keyboard Replacement, Keyboard Pad Replacement: stap 7, afbeelding 1 van 2 Samsung Blast Keyboard Replacement, Keyboard Pad Replacement: stap 7, afbeelding 2 van 2
    • Slide the keyboard straight up to free it from its alignment pins.
    • Swap the broken keyboard with a replacement here, and follow the repair steps in reverse order for reassembly.
Conclusie
Jordan Taylor
10 Reputatie
1 Handleiding geschreven
Ohio State, Team 1-5, Buehl Spring 2014 Lid van Ohio State, Team 1-5, Buehl Spring 2014
OSU-BUEHL-S14S1G5
4 Leden
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 397
