Ga door naar hoofdinhoud
Samsung Blast Back Cover Replacement
Wat je nodig hebt
  1. Samsung Blast Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Place the phone face down on the table. Locate a Phillips head screwdriver. Begin by first removing the four screws that surround the upper area of the Samsung phone.
  2. Samsung Blast Back Cover Replacement: stap 2, afbeelding 1 van 1
    • Next, remove the side button by prying open the the side of the phone with a prying tool. Insert the prying tool between the back cover and the remainder of the phone. Slide the prying tool to the left, creating a division between the cover and the phone.
  3. Samsung Blast Back Cover Replacement: stap 3, afbeelding 1 van 1
    • Continue using the prying tool to unlock the phone. If you hear a popping sound you know that you are on the right track. Be gentle as to not snap the screw-posts inside the case.
  4. Samsung Blast Back Cover Replacement: stap 4, afbeelding 1 van 1
    • Finally, remove the back cover by gently lifting the case up, ensuring that nothing is still attached to the cover.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Joseph
129 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 190
