Ga door naar hoofdinhoud
Samsung Blackjack Back Phone Casing Replacement
Wat je nodig hebt
  1. Samsung Blackjack Back Phone Casing Replacement, Battery Cover: stap 1, afbeelding 1 van 3 Samsung Blackjack Back Phone Casing Replacement, Battery Cover: stap 1, afbeelding 2 van 3 Samsung Blackjack Back Phone Casing Replacement, Battery Cover: stap 1, afbeelding 3 van 3
    • Hold the device with the screen facing away from you and the camera towards you.
    • Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
  2. Samsung Blackjack Back Phone Casing Replacement, Battery: stap 2, afbeelding 1 van 2 Samsung Blackjack Back Phone Casing Replacement, Battery: stap 2, afbeelding 2 van 2
    • Place your fingers on both sides of the bottom of the battery and lift upwards.
    • Pull the battery away from the phone.
  3. Samsung Blackjack Back Phone Casing Replacement, SIM Card: stap 3, afbeelding 1 van 3 Samsung Blackjack Back Phone Casing Replacement, SIM Card: stap 3, afbeelding 2 van 3 Samsung Blackjack Back Phone Casing Replacement, SIM Card: stap 3, afbeelding 3 van 3
    • Place your thumb on the SIM card.
    • Slide the card out of the slot.
  4. Samsung Blackjack Back Phone Casing Replacement, Back Phone Casing: stap 4, afbeelding 1 van 2 Samsung Blackjack Back Phone Casing Replacement, Back Phone Casing: stap 4, afbeelding 2 van 2
    • Use the spudger to remove the rubber stoppers from the top of the cover.
    • Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
  5. Samsung Blackjack Back Phone Casing Replacement: stap 5, afbeelding 1 van 3 Samsung Blackjack Back Phone Casing Replacement: stap 5, afbeelding 2 van 3 Samsung Blackjack Back Phone Casing Replacement: stap 5, afbeelding 3 van 3
    • Use the spudger to loosen and separate the front and back covers.
    • Pick up the back cover once loosened.
    • The front and back covers will be attached to each other by a gold wire.
    • Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
Conclusie
Kristin Manna
29 Reputatie
10 handleidingen geschreven
Clemson, Team 14-4, Benson Fall 2012 Lid van Clemson, Team 14-4, Benson Fall 2012
CLEM-BENSON-F12S14G4
3 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 497
