Ga door naar hoofdinhoud
Samsung BlackJack II Keypad Replacement
Wat je nodig hebt
  1. Samsung BlackJack II Keypad Replacement, Battery: stap 1, afbeelding 1 van 3 Samsung BlackJack II Keypad Replacement, Battery: stap 1, afbeelding 2 van 3 Samsung BlackJack II Keypad Replacement, Battery: stap 1, afbeelding 3 van 3
    • Apply downward pressure to the top of the battery panel while pulling down to slide it off the phone.
  2. Samsung BlackJack II Keypad Replacement: stap 2, afbeelding 1 van 3 Samsung BlackJack II Keypad Replacement: stap 2, afbeelding 2 van 3 Samsung BlackJack II Keypad Replacement: stap 2, afbeelding 3 van 3
    • Locate the grooves on the sides of the battery near the bottom of the phone. Use your fingers to pull the battery up and out of the phone.
  3. Samsung BlackJack II Keypad Replacement, Back Casing: stap 3, afbeelding 1 van 2 Samsung BlackJack II Keypad Replacement, Back Casing: stap 3, afbeelding 2 van 2
    • Use the spudger to pry the two plastic caps out of the top corners of the phone casing.
    • To get a better grip, you may use the tweezers to finish pulling the plastic caps from the phone.
  4. Samsung BlackJack II Keypad Replacement: stap 4, afbeelding 1 van 1
    • Remove the six 4.0 mm screws using the Phillips 00 screwdriver.
  5. Samsung BlackJack II Keypad Replacement: stap 5, afbeelding 1 van 3 Samsung BlackJack II Keypad Replacement: stap 5, afbeelding 2 van 3 Samsung BlackJack II Keypad Replacement: stap 5, afbeelding 3 van 3
    • Insert the plastic opening tool in the gap between the back panel and rest of the body.
    • Slide the tool along the edges until the two pieces come apart.
    • The circuit board is attached to the front casing. Both casings should separate without having to sever electrical connections.
  6. Samsung BlackJack II Keypad Replacement, Front Casing: stap 6, afbeelding 1 van 2 Samsung BlackJack II Keypad Replacement, Front Casing: stap 6, afbeelding 2 van 2
    • Pry apart the plastic tabs along the edges of the phone.
    • Separate the front panel from the main body of the phone using your fingers.
  7. Samsung BlackJack II Keypad Replacement, Keypad: stap 7, afbeelding 1 van 1
    • Peel back the rubber keypad from the front casing.
Conclusie
Ryan Rumsey
8 Reputatie
6 handleidingen geschreven
Cal Poly, Team 20-1, Maness Winter 2013 Lid van Cal Poly, Team 20-1, Maness Winter 2013
CPSU-MANESS-W13S20G1
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 325
