Ga door naar hoofdinhoud
Samsung BD-JM57C Power Cord Replacement
Wat je nodig hebt
  1. Samsung BD-JM57C Power Cord Replacement, Top Cover: stap 1, afbeelding 1 van 2 Samsung BD-JM57C Power Cord Replacement, Top Cover: stap 1, afbeelding 2 van 2
    • Use the Phillips #00 Screwdriver to remove the single 9.6mm screw holding the top cover in place.
    • Remove the cover by sliding it up and then out.
  2. Samsung BD-JM57C Power Cord Replacement, Disc Drive: stap 2, afbeelding 1 van 2 Samsung BD-JM57C Power Cord Replacement, Disc Drive: stap 2, afbeelding 2 van 2
    • Disconnect the two ribbons that connect the disc drive to the motherboard.
  3. Samsung BD-JM57C Power Cord Replacement: stap 3, afbeelding 1 van 2 Samsung BD-JM57C Power Cord Replacement: stap 3, afbeelding 2 van 2
    • Push in on the two metal tabs on the side of the disc drive.
    • Push forward to slide the disc drive out of the casing.
  4. Samsung BD-JM57C Power Cord Replacement, WiFi Card: stap 4, afbeelding 1 van 2 Samsung BD-JM57C Power Cord Replacement, WiFi Card: stap 4, afbeelding 2 van 2
    • Pull clip to remove the WiFi card ribbon connected to the circuit board.
    • Push the black plastic tab out and slide the WiFi card out from the cage.
  5. Samsung BD-JM57C Power Cord Replacement, Power Cord: stap 5, afbeelding 1 van 2 Samsung BD-JM57C Power Cord Replacement, Power Cord: stap 5, afbeelding 2 van 2
    • Use the Phillips #00 Screwdriver to remove the two 6.4 mm screws holding the cage in place.
    • Lift the cage up to remove it.
  6. Samsung BD-JM57C Power Cord Replacement: stap 6, afbeelding 1 van 1
    • Push in the small white lever and pull it towards you to release the cord.
  7. Samsung BD-JM57C Power Cord Replacement: stap 7, afbeelding 1 van 1
    • Move the power cord out from under the metal tab on the side of the case.
  8. Samsung BD-JM57C Power Cord Replacement: stap 8, afbeelding 1 van 1
    • Remove the rubber spacer on the edge of the case holding the cord in place.
    • Remove the power cord from the device.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 174
