Ga door naar hoofdinhoud
Samsung BD-JM57C Motherboard Replacement
Wat je nodig hebt
  1. Samsung BD-JM57C Motherboard Replacement, Top Cover: stap 1, afbeelding 1 van 2 Samsung BD-JM57C Motherboard Replacement, Top Cover: stap 1, afbeelding 2 van 2
    • Use the Phillips #00 Screwdriver to remove the single 9.6mm screw holding the top cover in place.
    • Remove the cover by sliding it up and then out.
  2. Samsung BD-JM57C Motherboard Replacement, Disc Drive: stap 2, afbeelding 1 van 2 Samsung BD-JM57C Motherboard Replacement, Disc Drive: stap 2, afbeelding 2 van 2
    • Disconnect the two ribbons that connect the disc drive to the motherboard.
  3. Samsung BD-JM57C Motherboard Replacement: stap 3, afbeelding 1 van 2 Samsung BD-JM57C Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Push in on the two metal tabs on the side of the disc drive.
    • Push forward to slide the disc drive out of the casing.
  4. Samsung BD-JM57C Motherboard Replacement, Power Cord: stap 4, afbeelding 1 van 2 Samsung BD-JM57C Motherboard Replacement, Power Cord: stap 4, afbeelding 2 van 2
    • Use the Phillips #00 Screwdriver to remove the two 6.4 mm screws holding the cage in place.
    • Lift the cage up to remove it.
  5. Samsung BD-JM57C Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Push in the small white lever and pull it towards you to release the cord.
  6. Samsung BD-JM57C Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Move the power cord out from under the metal tab on the side of the case.
  7. Samsung BD-JM57C Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the rubber spacer on the edge of the case holding the cord in place.
    • Remove the power cord from the device.
  8. Samsung BD-JM57C Motherboard Replacement, Motherboard: stap 8, afbeelding 1 van 1
    • After the power cord has been disconnected, remove the yellow circuit board from the Blu ray player.
    • There is nothing holding down the circuit board, do not forcefully remove it or try to remove other parts from it.
  9. Samsung BD-JM57C Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Use the Phillips #00 screwdriver to remove the 9.7mm screw holding the HDMI port in place on the outside of the case.
  10. Samsung BD-JM57C Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Use the Phillips #00 screwdriver to remove the 6.4mm screw holding the motherboard in place.
    • Pull the motherboard up to remove it from the device.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 481
