Inleiding
When dealing with a power board it is important to remember that all capacitors are charged until proven otherwise. Proceed with caution as capacitors can hold a strong charge and shock you when touched.
Wat je nodig hebt
Remove the 7 mm screw using a phillips head #J1 screwdriver.
To remove the ribbon cable, firmly grip the blue tab attached to the base and pull upwards.
Bijna klaar!
Conclusie
