Ga door naar hoofdinhoud
Samsung BD-F5900 Power Supply Replacement
Wat je nodig hebt
  1. Samsung BD-F5900 Power Supply Replacement, Top Cover: stap 1, afbeelding 1 van 1
    • Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
    • Tilt the back of the top cover forward to remove from chassis.
  2. Samsung BD-F5900 Power Supply Replacement: stap 2, afbeelding 1 van 1
    • Gently pull up on the ribbon cable by the blue tab to remove it from the power supply board.
  3. Samsung BD-F5900 Power Supply Replacement, Power Supply: stap 3, afbeelding 1 van 2 Samsung BD-F5900 Power Supply Replacement, Power Supply: stap 3, afbeelding 2 van 2
    • Using a #1 Phillips head screwdriver, remove the two 7.5mm screws on top of the plastic cover and remove the cover.
  4. Samsung BD-F5900 Power Supply Replacement: stap 4, afbeelding 1 van 1
    • Press down on the plastic retaining clip and pull backwards to remove the AC power connector from the power supply board.
  5. Samsung BD-F5900 Power Supply Replacement: stap 5, afbeelding 1 van 3 Samsung BD-F5900 Power Supply Replacement: stap 5, afbeelding 2 van 3 Samsung BD-F5900 Power Supply Replacement: stap 5, afbeelding 3 van 3
    • Using the plastic spudger tool, gently pry on either side of main power connector (CON801) to disconnect from main logic board.
    • Pry a little bit on each side of board until the board lifts away.
    • Tilt the board forward and lift up to remove from the chassis.
Conclusie
Louis McKean
528 Reputatie
5 handleidingen geschreven
USF Tampa, Team S1-G21, Cagle Fall 2017 Lid van USF Tampa, Team S1-G21, Cagle Fall 2017
USFT-CAGLE-F17S1G21
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 255
