Ga door naar hoofdinhoud
Samsung BD-E5400 Wi-Fi Card Replacement
Wat je nodig hebt
  1. Samsung BD-E5400 Wi-Fi Card Replacement, Outer Cover: stap 1, afbeelding 1 van 2 Samsung BD-E5400 Wi-Fi Card Replacement, Outer Cover: stap 1, afbeelding 2 van 2
    • Remove the two 10mm Phillips #1 screws.
    • Remove the one 8 mm Phillips #1 screw.
    • Carefully lift up the cover and lay back, to ensure that you do not damage the attached cable.
  2. Samsung BD-E5400 Wi-Fi Card Replacement: stap 2, afbeelding 1 van 1
    • Unplug the small wiring bundle attaching the body of the device to the cover.
    • Lay the cover aside.
  3. Samsung BD-E5400 Wi-Fi Card Replacement, WIFI Card: stap 3, afbeelding 1 van 3 Samsung BD-E5400 Wi-Fi Card Replacement, WIFI Card: stap 3, afbeelding 2 van 3 Samsung BD-E5400 Wi-Fi Card Replacement, WIFI Card: stap 3, afbeelding 3 van 3
    • The Wi-Fi card is the light blue component circled in red.
    • Separate the body of the Wi-Fi card from the black plastic cover.
    • Unplug the wires of the Wi-Fi card from the motherboard.
Conclusie
Cameron Herring
306 Reputatie
3 handleidingen geschreven
IUPUI, Team S1-G3, Arle Fall 2018 Lid van IUPUI, Team S1-G3, Arle Fall 2018
IUPUI-ARLE-F18S1G3
3 Leden
4 handleidingen geschreven
Één opmerking
I replaced my wifi card now none of the apps are working. I tried factory reset, and updating firmware nothing. Any ideas to get past this?
mike monroe - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 292
