Inleiding
This is a replacement guide for the Samsung BD-D5500 Blu-ray player. This guide will personally give you the information you need to replace the disc tray of the device. This is a very easy and simple process.
Wat je nodig hebt
To begin, turn the device over so that the bottom is facing up. There are 9 black clips that attach the plastic body to the case. Remove these clips from the case.
To remove the disc hub all you have to do is remove the 4 screws holding it down.
