Ga door naar hoofdinhoud
Samsung Admire Speaker Replacement
Wat je nodig hebt
  1. Samsung Admire Speaker Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Use your fingernail or plastic opening tool to pull up the back cover of the phone from under the slit.
  2. Samsung Admire Speaker Replacement, Remove the battery: stap 2, afbeelding 1 van 1
    • Carefully remove the battery by placing your fingernail underneath the hole and pulling out the battery.
    • Your hands should not be wet.
  3. Samsung Admire Speaker Replacement, Remove the screws: stap 3, afbeelding 1 van 3 Samsung Admire Speaker Replacement, Remove the screws: stap 3, afbeelding 2 van 3 Samsung Admire Speaker Replacement, Remove the screws: stap 3, afbeelding 3 van 3
    • Use the Phillips #00 Precision Screwdriver to remove the six screws in the back of the phone.
  4. Samsung Admire Speaker Replacement, Inside back cover: stap 4, afbeelding 1 van 3 Samsung Admire Speaker Replacement, Inside back cover: stap 4, afbeelding 2 van 3 Samsung Admire Speaker Replacement, Inside back cover: stap 4, afbeelding 3 van 3
    • Use the plastic opening tools to remove the inside back cover.
    • Place the plastic opening tools on the outside rim of the inside back cover.
    • Carefully lift the cover and circle around the rim to open the inside back cover completely.
    • Carefully disconnect ribbon cables and slowly lift the inside back cover to remove it.
  5. Samsung Admire Speaker Replacement, Speaker: stap 5, afbeelding 1 van 2 Samsung Admire Speaker Replacement, Speaker: stap 5, afbeelding 2 van 2
    • The speaker is located within the inside of the back cover.
    • Simply remove it by lifting it off with the plastic opening tool.
Conclusie
Thao Uyen Do
896 Reputatie
4 handleidingen geschreven
USF Tampa, Team 7-5, Remmell Winter 2015 Lid van USF Tampa, Team 7-5, Remmell Winter 2015
USFT-REMMELL-W15S7G5
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 12
Altijd: 737
