Ga door naar hoofdinhoud
Samsung Admire Camera Replacement
Wat je nodig hebt
  1. Samsung Admire Camera Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Use your fingernail or the plastic opening tool under the slit to pull the back cover off.
  2. Samsung Admire Camera Replacement, Remove the Battery: stap 2, afbeelding 1 van 1
    • Making sure your hands are dry, insert your fingernail beneath the battery and remove it.
  3. Samsung Admire Camera Replacement, Remove the screws: stap 3, afbeelding 1 van 3 Samsung Admire Camera Replacement, Remove the screws: stap 3, afbeelding 2 van 3 Samsung Admire Camera Replacement, Remove the screws: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Magnetic Project Mat
    $19.95
    • Use a Phillips #00 Precision Screwdriver to remove the six screws in the back of the phone.
    • Place the screws on a magnetic mat to prevent losing them.
  4. Samsung Admire Camera Replacement, Inside back Cover: stap 4, afbeelding 1 van 3 Samsung Admire Camera Replacement, Inside back Cover: stap 4, afbeelding 2 van 3 Samsung Admire Camera Replacement, Inside back Cover: stap 4, afbeelding 3 van 3
    • Place the Plastic Opening tool on the outside rim of the back cover.
    • Carefully circle around the rim to open the inside back cover completely.
    • Disconnect the ribbon cables and remove the back cover.
  5. Samsung Admire Camera Replacement, Motherboard: stap 5, afbeelding 1 van 3 Samsung Admire Camera Replacement, Motherboard: stap 5, afbeelding 2 van 3 Samsung Admire Camera Replacement, Motherboard: stap 5, afbeelding 3 van 3
    • Carefully disconnect the volume button, the microphone connector, and the screen connector from the motherboard.
    • Pull back the side clips and lift the motherboard slowly.
  6. Samsung Admire Camera Replacement, Camera: stap 6, afbeelding 1 van 2 Samsung Admire Camera Replacement, Camera: stap 6, afbeelding 2 van 2
    • Use the plastic opening tool to disconnect the camera from the phone.
    • Connect the new camera into the motherboard.
Conclusie
12 andere personen hebben deze handleiding voltooid.
Thao Uyen Do
926 Reputatie
4 handleidingen geschreven
USF Tampa, Team 7-5, Remmell Winter 2015 Lid van USF Tampa, Team 7-5, Remmell Winter 2015
USFT-REMMELL-W15S7G5
4 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 34
Altijd: 1,873
