Inleiding
If your current case is damaged, this guide will help you install a new case to protect your phone from further abuse.
Wat je nodig hebt
To remove the back casing, firmly press down and push towards the bottom of the phone.
Using the Phillips #00 screwdriver, remove the four indicated screws (4.5 mm).
Bijna klaar!
Conclusie
