Ga door naar hoofdinhoud
Samsung ATIV Book 9 Speaker Replacement
Wat je nodig hebt
  1. Samsung ATIV Book 9 Speaker  Replacement, Speaker: stap 1, afbeelding 1 van 2 Samsung ATIV Book 9 Speaker  Replacement, Speaker: stap 1, afbeelding 2 van 2
    • Put a protective lining such as a piece of cloth in between the screen and the keyboard when closed to protect your screen when performing this replacement.
    • Turn the laptop upside down to show the screws holding the back cover on.
    • Using the Phillips #0, remove the ten 4mm screws located around the edges and one central.
  2. Samsung ATIV Book 9 Speaker  Replacement: stap 2, afbeelding 1 van 3 Samsung ATIV Book 9 Speaker  Replacement: stap 2, afbeelding 2 van 3 Samsung ATIV Book 9 Speaker  Replacement: stap 2, afbeelding 3 van 3
    • Use two plastic opening tools to separate the back cover from the laptop.
    • This may take some force because the back cover is snapped into place before the screws are used to keep it in place.
  3. Samsung ATIV Book 9 Speaker  Replacement: stap 3, afbeelding 1 van 3 Samsung ATIV Book 9 Speaker  Replacement: stap 3, afbeelding 2 van 3 Samsung ATIV Book 9 Speaker  Replacement: stap 3, afbeelding 3 van 3
    • Using the Phillips #0, remove the seven 5mm screws highlighted in the image.
    • Using your hands, disconnect the battery's main cord from the main motherboard.
    • Using your hands, remove the battery from the computer.
  4. Samsung ATIV Book 9 Speaker  Replacement: stap 4, afbeelding 1 van 3 Samsung ATIV Book 9 Speaker  Replacement: stap 4, afbeelding 2 van 3 Samsung ATIV Book 9 Speaker  Replacement: stap 4, afbeelding 3 van 3
    • Using a Phillips #1, remove the two 3mm screws, one per speaker.
    • Using the nylon spudger, release the black and red wires that connect the two speakers.
  5. Samsung ATIV Book 9 Speaker  Replacement: stap 5, afbeelding 1 van 3 Samsung ATIV Book 9 Speaker  Replacement: stap 5, afbeelding 2 van 3 Samsung ATIV Book 9 Speaker  Replacement: stap 5, afbeelding 3 van 3
    • Using your hands, remove the cord that connects the speakers to the board you are removing.
    • Do not pull on the cord as that might damage it; remove it by pulling on the white wire head.
    • Using your hands remove the speakers from the computer. This may require some force as they are held in place partially by double sided tape.
Conclusie
Phat Tran
786 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 562
