Ga door naar hoofdinhoud
Samsung ATIV Book 9 Plus Speakers Replacement
Wat je nodig hebt
  1. Samsung ATIV Book 9 Plus Speakers Replacement, Back Cover: stap 1, afbeelding 1 van 3 Samsung ATIV Book 9 Plus Speakers Replacement, Back Cover: stap 1, afbeelding 2 van 3 Samsung ATIV Book 9 Plus Speakers Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Speakers Replacement: stap 2, afbeelding 1 van 1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Speakers Replacement, Speakers: stap 3, afbeelding 1 van 2 Samsung ATIV Book 9 Plus Speakers Replacement, Speakers: stap 3, afbeelding 2 van 2
    • The speakers are black, and form a block-like "L" shape around the bottom half of the battery.
    • Lift from the corners of the speakers to remove them.
  4. Samsung ATIV Book 9 Plus Speakers Replacement: stap 4, afbeelding 1 van 2 Samsung ATIV Book 9 Plus Speakers Replacement: stap 4, afbeelding 2 van 2
    • After lifting the body of the speaker out of the laptop, you will notice that the top of the speaker is connected to the laptop by cables.
    • Continue removing the speakers by gently squeezing the sides of the white connector.
  5. Samsung ATIV Book 9 Plus Speakers Replacement: stap 5, afbeelding 1 van 1
    • Gently tug on the white connector in order to remove the speakers.
Conclusie
Karoline DaVee
136 Reputatie
1 Handleiding geschreven
Baylor, Team 2-3, Grigsby Spring 2015 Lid van Baylor, Team 2-3, Grigsby Spring 2015
BU-GRIGSBY-S15S2G3
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 1,535
