Ga door naar hoofdinhoud
Samsung ATIV Book 9 Plus Heatsink Assembly Replacement
Wat je nodig hebt
  1. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Back Cover: stap 1, afbeelding 1 van 3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Back Cover: stap 1, afbeelding 2 van 3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: stap 2, afbeelding 1 van 1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Internal Fans: stap 3, afbeelding 1 van 3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Internal Fans: stap 3, afbeelding 2 van 3 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Internal Fans: stap 3, afbeelding 3 van 3
    • The fans should be in the upper left corner of the laptop if the laptop is oriented with the battery in the bottom half.
    • Gently lift the fans' black connector strip out of the way.
  4. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: stap 4, afbeelding 1 van 2 Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: stap 4, afbeelding 2 van 2
    • Using a Phillips head screwdriver, unscrew four 4.55 mm Phillips #000 screws that bind the fans.
  5. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the white connectors by gently tugging on them.
    • Lift the fans from their positions.
  6. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement, Heatsink Assembly: stap 6, afbeelding 1 van 1
    • Using a Phillips head screwdriver #000 unscrew the motherboard from the rest of the components.
  7. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the two cables shown in the picture by gently pulling them off.
  8. Samsung ATIV Book 9 Plus Heatsink Assembly Replacement: stap 8, afbeelding 1 van 1
    • Using a Phillips #000 screwdriver, unscrew the three labeled screws to detach the heatsink assembly.
Conclusie
Ryan Smith
193 Reputatie
2 handleidingen geschreven
IUPUI, Team S7-G7, Wilson Spring 2019 Lid van IUPUI, Team S7-G7, Wilson Spring 2019
IUPUI-WILSON-S19S7G7
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 680
