Ga door naar hoofdinhoud
Samsung ATIV Book 9 Plus Charger Port Replacement
Wat je nodig hebt
  1. Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: stap 1, afbeelding 1 van 3 Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: stap 1, afbeelding 2 van 3 Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Charger Port Replacement: stap 2, afbeelding 1 van 1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Charger Port Replacement, Charger Port: stap 3, afbeelding 1 van 2 Samsung ATIV Book 9 Plus Charger Port Replacement, Charger Port: stap 3, afbeelding 2 van 2
    • Unscrew the 4.3mm screws holding down the plastic cover using a #000 screwdriver. After the screws are out remove the cover.
    • Remove the 4.3 mm screw holding down the metal cover using a #000 screwdriver.
  4. Samsung ATIV Book 9 Plus Charger Port Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the charging port from the motherboard by gently tugging on the plastic part of the connection.
  5. Samsung ATIV Book 9 Plus Charger Port Replacement: stap 5, afbeelding 1 van 1
    • Wedge a plastic opening tool or spudger in between the laptop casing and the port. Pry until you feel it release.
    • This will take some force because the port is glued to the casing.
  6. Samsung ATIV Book 9 Plus Charger Port Replacement: stap 6, afbeelding 1 van 1
    • Remove the disconnected charger port.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Casey Kauffman
329 Reputatie
2 handleidingen geschreven
IUPUI, Team S6-G6, Baechle Fall 2017 Lid van IUPUI, Team S6-G6, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G6
3 Leden
3 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 1,987
