Ga door naar hoofdinhoud
Samsung ATIV Book 9 NP900X3K-S01US SSD Replacement
Wat je nodig hebt
  1. Samsung ATIV Book 9 NP900X3K-S01US SSD Replacement, SSD: stap 1, afbeelding 1 van 1
    • Remove ten Phillips #00 screws from the back panel.
    • Remove the back panel.
  2. Samsung ATIV Book 9 NP900X3K-S01US SSD Replacement: stap 2, afbeelding 1 van 1
    • Unscrew the five Phillips #00 screws which connect the battery to the frame of the laptop.
    • Lift the battery from the bottom edge, taking care as it is disconnected from the motherboard.
    • During reassembly, insert the top edge of the battery first, aligning the pins of the battery with the pins of the motherboard connection.
  3. Samsung ATIV Book 9 NP900X3K-S01US SSD Replacement: stap 3, afbeelding 1 van 1
    • Remove the interconnect ribbon cable labeled “main” and “sub” by prying the pin connections up with a spudger or plastic opening tool.
  4. Samsung ATIV Book 9 NP900X3K-S01US SSD Replacement: stap 4, afbeelding 1 van 1
    • Remove the single screw holding down the SSD with a Phillips #00 screwdriver.
    • Remove the SSD from its slot located to the right, just above the battery.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 923
