Inleiding
Is your Samsung ATIV Book 9 experiencing any power related battery issues such as power loss or screen flickering? This guide is here to assist you with any issues concerning the battery. A Phillips #00 screwdriver is needed to remove the battery for replacement.
Wat je nodig hebt
Close the device and rest it on a flat surface.
Flip the device over to access the ten 4.3 mm screws located on the bottom case.
Remove all ten screws using the Phillips #00 screwdriver.
Using a Phillips #00 screwdriver, remove the six 4.3 mm screws securing the battery to the device.
