Ga door naar hoofdinhoud
Samsung ATIV Book 9 Lite Hard Drive Replacement
Wat je nodig hebt
  1. Samsung ATIV Book 9 Lite Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 2 Samsung ATIV Book 9 Lite Hard Drive Replacement, Hard Drive: stap 1, afbeelding 2 van 2
    • Put a protective lining such as a piece of cloth in between the screen and the keyboard when closed to protect your screen when performing this replacement.
    • Turn the laptop upside down to show the screws holding the back cover on.
    • Using a Phillips #0, remove the ten 4mm screws located around the edges and one central.
  2. Samsung ATIV Book 9 Lite Hard Drive Replacement: stap 2, afbeelding 1 van 3 Samsung ATIV Book 9 Lite Hard Drive Replacement: stap 2, afbeelding 2 van 3 Samsung ATIV Book 9 Lite Hard Drive Replacement: stap 2, afbeelding 3 van 3
    • Use two plastic opening tools to separate the back cover from the laptop.
    • This may take some force because the back cover is snapped into place before the screws are used to keep it in place.
  3. Samsung ATIV Book 9 Lite Hard Drive Replacement: stap 3, afbeelding 1 van 3 Samsung ATIV Book 9 Lite Hard Drive Replacement: stap 3, afbeelding 2 van 3 Samsung ATIV Book 9 Lite Hard Drive Replacement: stap 3, afbeelding 3 van 3
    • Using your hands or a plastic opening tool, release the yellow motherboard connection strip on both ends by lifting the clamps.
    • Remove the strip to reveal the hard drive.
  4. Samsung ATIV Book 9 Lite Hard Drive Replacement: stap 4, afbeelding 1 van 2 Samsung ATIV Book 9 Lite Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • Using a Phillips #0, remove the two 3mm screws holding the hard drive in place.
    • Remove the hard drive by pulling it out with your hands.
Conclusie
Phat Tran
786 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 33
Altijd: 4,545
