Ga door naar hoofdinhoud
Samsung ATIV Book 9 Lite Battery Replacement
Wat je nodig hebt
  1. Samsung ATIV Book 9 Lite Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Samsung ATIV Book 9 Lite Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Put a protective lining such as a piece of cloth in between the screen and the keyboard when closed to protect your screen when performing this replacement.
    • Turn the laptop upside down to show the screws holding the back cover on.
    • Using a Phillips #0, remove the ten 4mm screws located around the edges and one central.
  2. Samsung ATIV Book 9 Lite Battery Replacement: stap 2, afbeelding 1 van 3 Samsung ATIV Book 9 Lite Battery Replacement: stap 2, afbeelding 2 van 3 Samsung ATIV Book 9 Lite Battery Replacement: stap 2, afbeelding 3 van 3
    • Use two plastic opening tools to separate the back cover from the laptop.
    • This may take some force because the back cover is snapped into place before the screws are used to keep it in place.
  3. Samsung ATIV Book 9 Lite Battery Replacement: stap 3, afbeelding 1 van 3 Samsung ATIV Book 9 Lite Battery Replacement: stap 3, afbeelding 2 van 3 Samsung ATIV Book 9 Lite Battery Replacement: stap 3, afbeelding 3 van 3
    • Using a Phillips #0, remove the seven 5mm screws highlighted in the image.
    • Using your hands, disconnect the battery's main cord from the main motherboard.
  4. Samsung ATIV Book 9 Lite Battery Replacement: stap 4, afbeelding 1 van 2 Samsung ATIV Book 9 Lite Battery Replacement: stap 4, afbeelding 2 van 2
    • Using your hands remove the battery from the computer.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Phat Tran
786 Reputatie
5 handleidingen geschreven
2 opmerkingen
please where can i get the battery 🔋
Bethel Ugwudike - Antwoord
Please where can i get the battery for Samsung 930x5j910s5j940x5j
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 1,676
