Ga door naar hoofdinhoud
Samsung ATIV Book 4 Screen Replacement
Wat je nodig hebt
  1. Samsung ATIV Book 4 Screen Replacement, Screen: stap 1, afbeelding 1 van 2 Samsung ATIV Book 4 Screen Replacement, Screen: stap 1, afbeelding 2 van 2
    • Be sure the computer is off, and open the computer so that the screen is showing.
    • Use the plastic opening tool and pry away the casing surrounding the screen. Remove the casing entirely.
  2. Samsung ATIV Book 4 Screen Replacement: stap 2, afbeelding 1 van 1
    • Remove the four 3.5mm screws securing the screen.
    • Tilt the screen back before removing the screws, there is a possibility it could fall and damage your keyboard or the ribbon cable connected to it.
  3. Samsung ATIV Book 4 Screen Replacement: stap 3, afbeelding 1 van 1
    • Place the screen gently on the keyboard.
  4. Samsung ATIV Book 4 Screen Replacement: stap 4, afbeelding 1 van 1
    • Remove the ribbon cable from the screen.
    • Remove and replace the screen.
Conclusie
Daniel
342 Reputatie
3 handleidingen geschreven
Michigan Tech, Team 1-7, Lauer Spring 2015 Lid van Michigan Tech, Team 1-7, Lauer Spring 2015
MTU-LAUER-S15S1G7
2 Leden
6 handleidingen geschreven
Één opmerking
Where do you buy the replacement screen for the ATIV Book 4? Thanks!
RMS015 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 3,396
