Ga door naar hoofdinhoud
Samsung 500C ChromeBook Battery Replacement
Wat je nodig hebt
  1. Samsung 500C ChromeBook Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Samsung 500C ChromeBook Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Use the spudger to remove the four rubber feet on the bottom panel.
    • Remove the seven Philips #1 screws.
  2. Samsung 500C ChromeBook Battery Replacement: stap 2, afbeelding 1 van 3 Samsung 500C ChromeBook Battery Replacement: stap 2, afbeelding 2 van 3 Samsung 500C ChromeBook Battery Replacement: stap 2, afbeelding 3 van 3
    • Remove the seven Phillips #1 screws holding the battery in place.
    • Detach the battery connector by pulling the connector towards the battery.
    • Pull from the plastic connector, do not pull from the wires.
    • Remove the battery.
    • When reinserting the battery, it is easier to insert from the long end first before lowering the rest of the battery into place.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Garrett Kissinger
704 Reputatie
5 handleidingen geschreven
Michigan Tech, Team 1-2, Lauer Spring 2014 Lid van Michigan Tech, Team 1-2, Lauer Spring 2014
MTU-LAUER-S14S1G2
3 Leden
10 handleidingen geschreven
3 opmerkingen
Samsung 500C ChromeBook Battery where to buy?
Uzi Naveh - Antwoord
I keep typing charger and all you is replacing the battery. Without a charger I can't know if the battery is bad. Can you help or not???
Carol South - Antwoord
Don't show my NAME
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 20
Altijd: 3,205
