Inleiding
The back panel is the "lid" that covers many of the monitors electrical components. Therefore this is a prerequisite for most of the other repair guides on this device.
Wat je nodig hebt
Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
Gereedschap gebruikt in deze stap:Heavy-Duty Spudger$4.99
Insert the heavy duty spudger in between the monitors back panel and its frame.
Use the heavy duty spudger to pry open the back panel.
Bijna klaar!
Conclusie
