Ga door naar hoofdinhoud
Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement
Wat je nodig hebt
  1. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Battery: stap 1, afbeelding 1 van 2 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove all external power and turn off the tablet.
    • Insert a plastic opening tool between the screen and rear casing.
    • Pry the screen and rear casing apart.
  2. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: stap 2, afbeelding 1 van 3 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: stap 2, afbeelding 2 van 3 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: stap 2, afbeelding 3 van 3
    • Remove the three green pieces of tape covering the white, black, and gold ribbon cables.
    • Use a spudger to flip up the retaining flap on the three ribbon cable ZIF sockets.
    • Pull the ribbon cables out of the sockets.
  3. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: stap 3, afbeelding 1 van 3 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: stap 3, afbeelding 2 van 3 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: stap 3, afbeelding 3 van 3
    • Remove the ten 4mm Phillips #000 screws from the battery.
    • Use a plastic opening tool to pry up the battery.
    • Remove the battery.
  4. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Home Button: stap 4, afbeelding 1 van 2 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Home Button: stap 4, afbeelding 2 van 2
    • Remove the green protective tape from the three ZIF connectors on the motherboard.
    • Pull the ribbon cables out of their sockets.
  5. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: stap 5, afbeelding 1 van 2 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: stap 5, afbeelding 2 van 2
    • Remove the six 4mm Phillips #000 screws from the motherboard.
    • Remove the motherboard.
  6. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: stap 6, afbeelding 1 van 2 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: stap 6, afbeelding 2 van 2
    • Insert a plastic opening tool between the screen and bezel.
    • Slide the plastic opening tool around the perimeter while applying a prying motion.
    • Remove the screen from the display.
    • Applying heat may be needed to loosed the glue.
  7. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: stap 7, afbeelding 1 van 2 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: stap 7, afbeelding 2 van 2
    • Locate the Home button on the front of the panel and carefully lift the gold ribbon surrounding it from RIGHT to LEFT.
  8. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: stap 8, afbeelding 1 van 1
    • Using your Phillips #000 screwdriver Remove the two 4mm Phillips #000 screws from the home button.
  9. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: stap 9, afbeelding 1 van 1
    • Remove the home button by sliding it to the left or right while pulling up.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Guneet Bawa
679 Reputatie
4 handleidingen geschreven
UW Tacoma, Team S1-G5, Liner Spring 2018 Lid van UW Tacoma, Team S1-G5, Liner Spring 2018
UWT-LINER-S18S1G5
5 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 18
Altijd: 1,973
