Inleiding
Gebruik deze handleiding om een beschadigd Samsonite-bagagewiel te vervangen.
Een beschadigd wiel kan blijven plakken, waardoor de koffer uit koers raakt of verhindert dat de koffer beweegt. Een vervangend wiel zal u helpen het probleem op te lossen.
Stap 1 helpt u ervoor te zorgen dat een vervanging nodig is en bereidt u voor op de vervanging.
Stap 2 helpt u bij het selecteren van het juiste vervangende onderdeel.
Wat je nodig hebt
Kies de juiste vervanger door de diameter en breedte van het wiel op te meten.
Measurement is vague to measure the wheel. Are you measuring the total width and length of the inside plate to determine the wheel size. Also, where can I get the wheels and what is the cost.
I have a 28 inch hard shell spinner.
These are the numbers on the tag.
20180126
4500470795
7213
4616
1109309
10
Is there a place in South Jersey to purchase the wheels.
Finding the proper replacement wheels has been my dilemma, as well. Tried the ones from Amazon that are almost the very same, but the screws do not seem to grasp. I am using the new parts on both sides. Samsonite says I need to bring it to their luggage store (100 miles away) and they will send it off, get the wheels replaced, send it back, all at my expense, but I don't know what that expense will be
Sally, I am in the same boat, looking for wheels. The Samsonite website gives general prices for shipping cases from their stores as needed but I don't remember what they are. Samsonite customer service was able to look up the wheels I needed but they are out of stock so they referred me to the authorized repair center in Colorado. I called them and was told they will not sell parts to the public and costs to replace wheels are 55.00 for the first wheel and 45.00 for each additional or 175.00 for all. At that price I can probably buy a new case on sale.
Plaats het nieuwe wiel op de koffer en zorg ervoor dat de uitstulpingen op de wielbasis uitgelijnd zijn met de gaten in de koffer.
You can see that it is NOT a NEW wheel! It's a shame, because the instructions would be useful if the case is otherwise still in good shape. Last year I unfortunately had to replace my good old Samsonite with a product from a competitor, because Samsonite no longer manufactures the product and has no suitable successor in its range ?! Since only the wheels were worn out, I looked for a replacement, but couldn't find a replacement (!) From the manufacturer, nor any usable alternatives, which is probably just not wanted in order to force a new purchase!
Here it would have been really useful how to install alternative rollerblade / inline wheels as a replacement!!!
Draai de schroeven vast die de clip op zijn plaats houden.
Very good guidence.Thanks
Please, where did you buy the replacement wheel? My suitcase looks very similar to yours.
Mine also looks exactly like the photo, but where can you buy the replacement? The assembly is elementary, but useless information if the new replacement is nowhere to be found!
Steven Z -
my struggle as well
5 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Toon Konings helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
25 opmerkingen
Where can i get replacement wheels
i have a samsonite luggage w 4 wheels can i change the wheels for 4 sets or 2 wheels each for easier rolling
Super tuto pas à pas pour changer sa roulette ! Ce n'est pas compliqué de réparer une valise et tous les fabricants ou importateurs le savent bien. Le plus dur est de trouver les bonnes pièces... Mais nous sommes là :) https://jereparemonbagage.com
Too bad no mention of where to find the wheels. Amazon.com does not show the wheels I need and Samsonite webpage is NO help at all.
home depot..... hardware
I agree totally!
I agree! The ones on Amazon are the wrong size and have bad reviews. Samsonite’s site is zero help. I hate to throw out a perfectly good suitcase with limited wear over a flat tire. I checked Home Depot per the comment above and didn’t see anything. Any other suggestions?
you can find them in aliExpress. I ordered from there and received it today and already fixed 1 wheel each on 2 Samsonite luggages.
https://www.aliexpress.us/item/325680508...
the above is the one fit perfectly for my samsonite luggages.
Where do you find the wheel replacement for Samsonite Ascella X 3.0
where do i find the replacement or can i give it to what shop to repair ?
Vervangen wielen Samsonite Handbagage boujaar 2004.
Ik heb 2 Samsonite handbagage productiejaar 2004. Deze handbagage heeft twee wieltjes. Heb de wieltjes nu vervangen.
Vond op internet interwiel.nl de benodigde wielen. Diameter 75 mm, asgat 8mm. Kost per wiel minder dan 2 euro.
Wieltjes zijn bevestigd in plastieken steunen. Die worden gedemonteerd door binnen in de valies 4 schroeven los te draaien.
Hiervoor heb je inwendige zeskant sleutel nodig. Ongeveer 30 minuten werk.
where I get replacement set of 4 wheels for Samsonite # 1000547
Alguien consiguió donde comprar las ruedas Samsonite ?
Try Amazon: e.g . SG10070 ASIN B07H29R7H6 or similar
VauWeh -
It is very frustrating for sure but I found these on Amazon and they fit my Samsonite suitcases perfectly - BQLZR Black Spinner Luggage Wheel Left & Right Plastic Swivel Caster Wheels with 3 Holes,Hole Pitch (1.22"/1.22"/1.06"),for Luggage Suitcase Trolley 360 Degree. W024 is the size that my suitcases needed. Hope this helps.
I tried to hacksaw of the wheels for replacement but my hacksaw had no effect. Is it the case that it's made of titanium?
Where to buy a new wheel for my Samsonite soft top? Dia 75mm width 23mm.
Marks on the wheel : GSI Wheel / CKW046 / 25-02017C / 44-9L100
I need the wheels shown in your instructions. Where can I find them???
Regards
Eric
Agreed video does not offer any lead on purchasing replacements wheels. Looking for samsonite spinner mobile office wheels...Unable to read the number on the actual wheel but the number on the tag reads SAM-HNGTG-2572. Any help appreciated.
You might find replacement wheels here: replacement wheels
Google Lens to find model
