Inleiding
Disassemble a Cyborg Mouse.
Wat je nodig hebt
Use a Phillips #1 screw driver to open the back cover.
Gently push away the bottom part on the opposite side to the cable.
Use a Phillips #1 screwdriver to unscrew the big top mouse part with both buttons.
Use whatever you find appropriate (I used a screwdriver) to gently push the clips (yellow) and next push to one of the circles (red) to separate the big top part.
Use whatever you find appropriate (I used a screwdriver) to gently push the clips (red) and use whatever you find appropriate (I used a thin screwdriver bit) to push the pin (yellow).
Now if you very gently push to the bottom part of the cover, it should pop out on itself.
Use a Phillips #00 bit to unscrew two screws on the motherboard.
Carefully lift the whole motherboard out of the mouse.
