Ga door naar hoofdinhoud
SR405QM Battery Replacement
Wat je nodig hebt
  1. SR405QM Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Gently place the instrument upside-down on a soft surface.
    • Locate the battery cavity cap and screws.
  2. SR405QM Battery Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #2 head screwdriver to unscrew both screws. Two #1 1mm long screws.
  3. SR405QM Battery Replacement: stap 3, afbeelding 1 van 2 SR405QM Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove the cap by lifting upwards to reveal the battery.
  4. SR405QM Battery Replacement: stap 4, afbeelding 1 van 3 SR405QM Battery Replacement: stap 4, afbeelding 2 van 3 SR405QM Battery Replacement: stap 4, afbeelding 3 van 3
    • Gently lift the battery from the cavity.
    • Detach the battery completely by firmly pulling the fabric connector from the conducting end of the battery.
Conclusie
To reassemble your device, follow these instructions in reverse order with a fresh battery.
Chris Pittner
220 Reputatie
7 handleidingen geschreven
Cal Poly, Team 5-18, Forte Winter 2013 Lid van Cal Poly, Team 5-18, Forte Winter 2013
CPSU-FORTE-W13S5G18
4 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,149
