Inleiding
When some of the keys on your Spot X SpotXB Satellite Messenger keyboard don't work or stick, that defeats the whole point of having one in the first place, blocking your ability to use the device effectively. Well, it's not a problematic replacement to make. This guide will walk you through replacing the keys of your device.
Wat je nodig hebt
Turn off the device completely by holding the power button for 10-20 seconds to force a shutdown.
Remove the ten 2.9 mm screws from the motherboard using a T5 Torx screwdriver.
Één andere persoon heeft deze handleiding voltooid.
